Edge Firmware 2.40
  • http://www.garmin.com/support/download_details.jsp?id=1243
    änderungen zwischen 2.30 und 2.40
    • Improved Courses to function off of location based logic. When doing a Course the user is now matched to a position along the Course based on location and heading. Allows users to join Courses at any point during their ride and have the Course synchronized to their position.
    • Changed to allow Autolap in Courses.
    • Show Compass page with guidance when doing a Course.
    • Add 'Distance to Next' and 'Time to Next' fields on the Compass page.
    • Disabled redundant Alerts during Workouts.
    • Keep GPS page in page loop if there is no GPS fix.
    • Allow editing of the position and elevation when marking a location.
    • Add ability to find nearest locations and to delete all.
    • Add ability to put GPS in Autolocate mode by holding DOWN when powering on.
    • Add quick settings lists to Quick Workout setup.
    • Add Warmup and Cooldown to Interval Training feature.
    • Seperated the distance and elevation units setup values.
    • Fix problem that could occur on workout lists from too many Workouts or Workout Steps.
    • Fix problem where calories would sometimes not reset after upload to Training Center.
    • Fix problem with distance not updating and track not recording if unit was powered down while plugged into USB, and then powered back on without ever being disconnected.
    • Fix problem with Autopause not working when set to 0 or stopped.
    • Fix problem with potential slowdown and lockup on Altimeter page.
    • Fix problem with reporting invalid cadence values when sensor not present.
    • Added support for nRoute.
    • Added Slovakian and Slovenian Languages.
    • Updated translations.
    • Fix problem where multiple cadence sensors not being stored off for separate bike profiles.
    • Power off USB pins when not connected.
    Idefix
    leider habe ich den Beitrag erst nach dem update auf 2.4 gefunden.
    Wirds auch das patch für 2.4 geben?
    Patch scheint nur mit 2.3zu funktionieren, wie es im Patchscreen steht!
    Zitat von webster@19.04.2006 - 13:09
    so wie es aussieht wurde die Seite inzwischen aktualisiert. :8
    Nun gibt es den Patch für die V2.40.
    Ciaoi Sidekick
    gibts das Patch auch für die aktuelle 2.6 Software ?
    Gruß Uli
