Gert, I'm zooming out and in, and... no time at all.
Any other hints?
TwoNav BETA 2.5.8.q
Heißt das, dass Korrekturen/Verbesserungen gleich dort geändert werden und dann wieder hochgeladen werden?
Nein. Die MD5 Prüfsumme hat sich nicht geändert.
No,
that's the way i could reproduce it. -
Forget about it as it's a yet not ready+buggy feature(maybe for next versions).
@Gert
Time in elevation profile has nothing common with zoom in/zoom out.
It only appears in hard GPS-signal conditions. On open air and clear sky everything is fine and just distance is shown.
Time appears after receiving GPS-fix and subsequent "acquiring" (NO GPS fix and yellow dot at map screen) and TURNING OFF/TURNING ON recording of the track.
Regards,
Marek
